weld pro stars
Old May 29, 2005 | 02:38 AM
cgas55's Avatar
Default weld pro stars
Hello I just bought a set of weld prostars and was wondering if anyone had any idea on what spacers i need for the front and rear wheels for clearance. The fronts are 15x4 the rear are 15x8. Any help would be great!
Thanks
Justin
Old May 29, 2005 | 02:41 AM
cgas55's Avatar
Default prostars
I have a 01 Z-28 by the way. I forgot to mention that.
Thanks
Justin
Old May 29, 2005 | 03:03 AM
Sandmann120's Avatar
What backspacing do you have?
Old May 29, 2005 | 09:03 AM
scalemaster's Avatar
try 5/16
Old May 29, 2005 | 03:06 PM
Joe-Ls1's Avatar
Thanks
Justin
if you have 15x 8 with 5.5 back spacing just grind the caliper until it clears the wheel from rubbing and use 5/16 spacer for the front wheels only. That's what i did to mine . I did not have no problems just remember that you need patience when you grind the rear caliper it is a time consuming.
Old May 29, 2005 | 08:38 PM
LS69TA's Avatar
It took me like 5 hrs. to do all 4 corners. Take your time and grind only what's needed to stop the rubbing, then maybe a thousandth or two for the calipers to expand.
Old Jun 2, 2005 | 06:36 PM
forurwife's Avatar
i just got the same wheels and i dont wnato to grind the calipers in the back what space should i get
