help with wheel stud!
Old Jun 28, 2005 | 06:34 PM
tuffluck's Avatar
Default help with wheel stud!
after the repair from hell, another problem arose. when i torque my rims down to 100 ft/lbs, one of the studs, wheel lugs will reach 100 (the wrench lets me know), but will want to keep spinning when i try to tighten it more. the other studs don't move at all once they reach 100 ft/lbs, but this one will turn a little bit and then the torque wrench will catch (since it's reached it's 100 ft/lb goal). does this mean the lug is stripped or what's going on?
Old Jun 28, 2005 | 07:26 PM
TRYTHSS's Avatar
are these new wheel studs? if you just put in new studs, check to see if that studs is flush with the back of the rotor. if it isnt, this could be causing it to slip around.
Old Jul 5, 2005 | 09:14 AM
Derek98z's Avatar
be carefull because if the stud is slipping, I forsee major problems getting the lugnut back off.
Old Jul 6, 2005 | 03:43 PM
Xsta Z 28's Avatar
I'd say it is time to remove that stud and replace it.
Old Jul 6, 2005 | 03:55 PM
Dustin's Avatar
my roommate just had that problem, i tried to tell him if it is spinning then dont tighten it down, his response was "theres 4 already on there, it will be fine", i forsee his wheel rolling off at 120mph, lol.
