what size tires?
Depends on if you want them to ride closer to the outer lip witch gives it a meaner stance or in the middle like stock (56), or to the inside more for what ever reason. With a 9" rim you can go 36mm (way out) to 60mm offset (way in) from what I can tell. Probably your best bet would be 50 to 56.
Don’t forget the sticky wheel chart is not gospel just a helpful guide.
All cars are different. Any problems or mistakes arising from said chart is solely the responsibility of the wheel buyer and not that of one said wheel chart designer.
