My junk on Pro Stars
Old Sep 16, 2005 | 05:30 PM
TS6's Avatar
TS6
Default My junk on Pro Stars
And I lowered the back a tad....
Attached Thumbnails My junk on Pro Stars-400.jpg   My junk on Pro Stars-500.jpg
Old Sep 16, 2005 | 05:56 PM
MonsterZ28's Avatar
hey man what kind of hood do u have on that, it looks bad ***
Old Sep 16, 2005 | 06:42 PM
MattIROC's Avatar
nice. Very sexy.
Old Sep 16, 2005 | 07:18 PM
LC's Avatar
LC
28" ?
do you have better pics?
Old Sep 16, 2005 | 07:26 PM
TS6's Avatar
TS6
Its a Glasstek 4" cowl hood. 28" tires, 325/50/15 MT DR's.
Old Sep 16, 2005 | 07:31 PM
TS6's Avatar
TS6
pic, not sure if its better....
Old Sep 17, 2005 | 11:39 AM
revlimiter's Avatar
Looks good, my buddy has a gold z28 with pro stars.
Attached Thumbnails My junk on Pro Stars-goldz1.jpg   My junk on Pro Stars-z281.jpg   My junk on Pro Stars-z28.jpg
Old Sep 21, 2005 | 10:47 PM
zssman's Avatar
TS6, any pics from the rear. Curious if the m/ts stick out any. Any rubbing problems.
Old Sep 21, 2005 | 10:58 PM
Onyx Z's Avatar
Damn nice!
Old Sep 22, 2005 | 08:50 AM
TS6's Avatar
TS6
I run a 1/4" spacer out back, otherwise it would be VERY close. Otherwise I did a little hammer work (very light) and they are fine. They stick out about 1/2" at most, not bad.
Old Sep 22, 2005 | 10:09 AM
Derek98z's Avatar
very nice!
Old Sep 22, 2005 | 10:34 AM
Bryan @ Speed Inc.'s Avatar
i need the matching fronts. i just have the rears. i like it with the tire shine on those m.t.'s. that's hawt.
Old Sep 22, 2005 | 11:00 AM
SSilverSSurfer's Avatar
man thats some nice junk you got there
Old Sep 23, 2005 | 07:31 PM
00SS4780's Avatar
Sweet car man. I love the hood!
Old Sep 27, 2005 | 04:12 AM
2000zrocks's Avatar
how tall are the fronts? aspect ratio?
Old Sep 28, 2005 | 09:28 AM
2000blackta's Avatar
Looks great! I just bought a set of rears for my TA. Just curious about the sizes up front and out back, and how much grinding you had to do?
Old Sep 28, 2005 | 10:12 AM
TS6's Avatar
TS6
Fronts are just cheapy 165 radials, they are about 25.5" tall. FWIW, when I had 26" reard and these fronts the ABS and TCS never gave me a problem, so they must be close enough to stock height.
Lots of grinding is required, do a search because some members have posted pics of their calipers after grinding to give you an idea. I tried several different kinds of grinding discs, the sandpaper ones seemed to remove material faster but wore out quickly. I bought one for concrete grinding, and while I don't think it will ever wear out, it doesn't cut as fast as the others. I would however, recommend the concrete grinding disc as it will save you $$$ in pads and works pretty good.
Old Sep 29, 2005 | 09:55 AM
go to a home depot and get a 30 dollar grinder... it'll get the job done. unless you already have a grinder... if so. then get ready to break it out. WARNING.... WEAR SAFETY GLASSES!!!
Old Sep 29, 2005 | 10:15 AM
CrawlinWS6's Avatar
Import Patrol
Man the grinding and the cutting to fit prostars with large rears suck. I put about 10hrs into doing mine, but I also put in arp 3.25 wheel studs, and it anyone has tried pulling these thru, its hard as hell. Its agravating while fitting them and you may want to give up on it a few times. But trust me it is all worth while at the end.
