Lugnut torque on Draglites
Old Sep 18, 2005 | 01:06 PM
ss427ci's Avatar
Default Lugnut torque on Draglites
What is the required lugnut torque on Draglites? 100ft/lbs still? I was thinking less for some reason....
*I did a search and found tons of dyno sheets with Rear wheel hp/tq specs.
Old Sep 18, 2005 | 02:44 PM
BackinBlack02SS's Avatar
still 100
Old Sep 18, 2005 | 09:33 PM
ls2 bait's Avatar
the paperwork that came with my draglites said not to exceed 75 ft lbs.
Old Sep 19, 2005 | 12:13 AM
ss427ci's Avatar
Can I have a tie breaking answer from a 3rd party.
Old Sep 19, 2005 | 07:35 AM
ls2 bait's Avatar
why dont u contact weld directly? they could give u a definate answer. if u bought them newit should have had a sheet of paper with it showing torque specs and install instructions.
Old Sep 19, 2005 | 11:54 AM
Steve Burger's Avatar
LS1TECH Sponsor
It's 75 for Pro Stars. I would say go with that.
Old Sep 19, 2005 | 02:23 PM
If weld says 75, then go with 75. I have bogarts, which are even lighter and probably slightly more fragile, and I've always used 100 lb ft. Figured they would be similar, but I guess not. My apologies for the bad info.
Old Sep 19, 2005 | 09:42 PM
ss427ci's Avatar
No problem.
I bought them used on eBay and figured I would use this site for what it's worth......answers to LS1 related questions. I think I'll use the 75ft/lb figure, thanks guys
Old Sep 19, 2005 | 10:11 PM
WickEdSix98's Avatar
With stock size studs, its 80-90, with 1/2" studs, its 75-85 per weld instructions that came with my draglites.
Old Sep 19, 2005 | 10:39 PM
ss427ci's Avatar
Alrighty then, I'll go with 90 until I get ARP studs, thanks man.....I might have lost a wheel.
Old Sep 19, 2005 | 11:48 PM
SJM Manufacturing Inc's Avatar
If folks aren't aware of our Bogart FAQ, please note it as there are a few good tips for our Bogart users. Your wheels, depending on your studs should be adjusted per our chart listed in the FAQ.
Hope this helps,
Steve
