5x4.75 =120mm?
Old Sep 19, 2005 | 02:48 PM
CONVERTED's Avatar
Default 5x4.75 =120mm?
5x4.75 =120mm?
Old Sep 19, 2005 | 03:32 PM
AW/whiteZ-28's Avatar
Nope it's 120.65mm
4.75 is inches
Old Sep 19, 2005 | 03:47 PM
CONVERTED's Avatar
There is a guy selling me some evo hypersilver dark that says the they are 5x4.57" and 38mm offset.. I'm under the impression the correct bolt and off set is 120mm and 38mm..
Any suggestions.
Old Sep 19, 2005 | 08:58 PM
TooSlow02's Avatar
Any suggestions.
The correct bolt pattern is 5x4.75" or 5x120.65 mm. See the stickys at the top of this forum for all the correct offset ranges.
Old Sep 19, 2005 | 09:25 PM
CONVERTED's Avatar
Thank you much.
Old Sep 19, 2005 | 09:37 PM
JackZ28's Avatar
You really need to check the center hold, for the hub. That will make or break you. If it is too big, you could run into some serious issues.
