which one is better
IF we used an 8 inch wheel for a customer whom is restricted to using smaller tires i.e. class etc, we use larger backspace then weld or centerline. Either of weld or centerlines choices largest backspace option is 5.5 which is too small and pulls the wheel ~.75-1.25 inches outward from your wheel-well. This makes the wheel non-centered in the wheel well. From the back, the wheel looks odd
...We build our 8 inch wheels closer to the stock BS (stock 8 inch wheel) which centers the wheel correctly in the wheel-well as it was intended.
Steve
