Studs in rear axle?
Old Oct 13, 2005 | 01:04 AM
FBDYLVR's Avatar
Default Studs in rear axle?
I did a search and I found out that installing new longer studs in the rear axle is easy if you have TCS car. The question I have is how much of a hard time will I have hammering the old studs out and pulling the new studs through the speed sensor hole? Does it line up PERFECTLY w/ the studs? Or will it go in crooked?
