Need help please Z06 wheels oem offset!
Old Oct 20, 2005 | 05:53 PM
camaross305's Avatar
Default Need help please Z06 wheels oem offset!
Ok i just installed some 18x10.5's in the back with a 56mm offset. I searched and found a couple of answers but not exactly what im looking for. It looks like if i where to hit a huge dip the bump stop would rub on the inside of the wheels. How hard is it for this to happen? Should i do anyhting about it or just leave it be because its very rare? I just want some opinions on what has happened to you guys and the oem offset on 18x10.5 z06 in the back. BTW im running 285's and they fit fine between the tire and fender still have 1/4-1/2 inch. Just need some sugestions on what i should do. Thanx in advace guys.
Old Oct 21, 2005 | 01:38 AM
ttt.........
Old Oct 21, 2005 | 08:40 AM
Xsta Z 28's Avatar
Unless you do a Dukes of Hazzard jump, you will never contact the bump stop.
I've runn 1" and 10.5" wheels and NEVER modified the bumps stop and NEVER had an issue.
Old Oct 21, 2005 | 09:31 AM
SUTTERERMAN85's Avatar
it will only hit if you jack up the car and unload the rear axle. or you take it off some sweet jumps or something
Old Oct 21, 2005 | 11:56 AM
ok cool that makes me much happier then....thanx for all the info guys
