56mm off set = inches?
Old Oct 27, 2005 | 07:31 PM
01WS6vert's Avatar
Default 56mm off set = inches?
What is the standard 56mm offset equal to in inches??
Old Oct 27, 2005 | 07:50 PM
SPANKY LS1's Avatar
What width rim?
On a 9.5" rim, its about 6.95"
On a 10.5" rim, its about 7.45"
[rim width/2]+[mm offset x 0.0393700787]
Old Oct 27, 2005 | 09:38 PM
komik's Avatar
The rim width doesn't matter. A 56 mm offset is a 2.2047244072 inch offset on any size rim.
SPANKY LS1, the numbers you posted would be the backspacing measurement on the respective rim sizes. However, your math is correct.
01WS6vert, a +56 mm offset is a +2.2047244072 inch offset.
Old Oct 27, 2005 | 10:25 PM
Xsta Z 28's Avatar
1" = 25.4 mm just FYI.
Old Oct 28, 2005 | 06:47 PM
SPANKY LS1's Avatar
I assumed he wanted to know the backspacing, not the offset in inches.
To determine backspacing, you would add 1/2 of the rim width to the backspacing in inches....
You're right though, the offset, by itself, has nothing to do with the width of the rim.
Shawn
