Will these fit?
Old Oct 27, 2005 | 09:58 PM
SMDLS1's Avatar
Default Will these fit?
Will a 26" tall 12"wide 15" drag tire fit on a 02 F body? Thanks Guys
Old Oct 29, 2005 | 01:17 AM
SMDLS1's Avatar
anybody
Old Oct 29, 2005 | 01:51 AM
setxws6's Avatar
Should fit on a 15" rim, if that's what you mean. Stock wheels are 16" or 17".
Old Oct 30, 2005 | 12:38 AM
SMDLS1's Avatar
I know they will fit on a 15" rim. I am about to buy some bogarts and I can get whatever size wheel I want. I am wanting to put M&H racemasters drag slicks on the rear. I want to go with a 26" tall 12" wide tire if it will fit on the rear with out any rubbing issues, but if not I will just go with 10" wide slick. Thanks for the help though. Anybody else?
Old Oct 30, 2005 | 02:36 AM
setxws6's Avatar
Those are about an 1 1/2 inches wider than most 315 drag radial, I just check the "sec" part in Jegs on those tires. They will rub badly with normal offset. However, if you get with Bogart and they get you an offset and backspacing that will push the wheel and tires further away from the wheel well, then it could work. Just got to get with someone that can help you on the backspacing specs you will need...
