Best Tires
Old Oct 31, 2005 | 01:53 PM
z06888's Avatar
Question Best Tires
Hi Guys
I 've 00 camaro M6 stock differential.
I need but 15 weld wheels.
1. what is best rim width 8 or 10?
2. what is best tire size for this rim?
3. what is defrnt between ET Street Series tires & ET Drag Series tires M/T? & what is best for street &truck used?
Old Oct 31, 2005 | 03:46 PM
z06888's Avatar
Pls. I wait your help
Old Oct 31, 2005 | 04:11 PM
Louie83's Avatar
Originally Posted by z06888
Hi Guys
1. For more traction, you are going to want the 10 inch rim. It also looks much better.
2. Read the very first sticky at the top of this forum. It will answer this question and many more of your questions much better than I can.
3. Well, the street series is clearly going to be better for the street, and the drag series better for drag racing. The drag racing tires will be illegal for use on the street though and can only be used on the track. Even though the street series says "street" doesn't mean it is always wonderful for daily driving. If you get caught in the rain, it could be quite scary as my friend's Mustang found out.
Old Oct 31, 2005 | 04:40 PM
OOOJOHN's Avatar
1 & 2 I like that 8 inch rim with the 10 inch wide tire.
3 I had et streets they were ok my friend had et drags they were ok . after runing hoosiers i will never buy another set of et streets or drags. I cant break those hoosiers loose if i tried.
the title said best tires ... my vote goes to the hoosiers (drag slicks)
