315/35R17's DO NOT FIT 9" or 9.5" WHEELS!!!
This will not be discussed. I will not tolerate that kind of post. If I see if posted it will be deleted no questions asked.
Read the tire manufacturers recommendations.
If you are foolish enough to try it fine . . .
If you find a tire shop ignorant enough to install them fine . . .
But encouraging others to recklessly experiment, NO. Do not PM me in regards to this, I will not reply. If you don't like my stance then complain to Brains or Nineball.
Sincerely,
The Tire ****
Sincerely,
The Tire ****
Until Nitto changes their printed documentation I will not allow discussion about Nitto 315/35ZR17 being acceptable on a 9" or 9.5"
Directly from Nitto's website: I have highlighted the tire so you can CLEARLY see.
555:
555R:
Proof is in the PRINTING . . . Nitto clearly state 10.5" MINIMUM wheel width.
1. If it is blatantly discussed I will edit the post
2. If you edit it back, you will receive a infraction.
3. If you still do not follow you will get a time out.
555:
555R:
