Need some help guys.
Old Dec 12, 2005 | 11:20 PM
azteca's Avatar
Question Need some help guys.
I just installed som z06 rep. on 02 ta and the rear rims look funny. Its a 50mm offset and the rim looks to far in the wheel well. Would a 1.25 spacer or 2.0 spacer make it look good. I just saw those two sizes on ebay. Thanks in advance.
Old Dec 13, 2005 | 08:32 AM
Xsta Z 28's Avatar
Seriously doubt they are 50 mm offset. Never heard of it being available. I know of 53 mm, 56 mm and 58 mm.
As for the spacer, sure anything is possible. Once you exceed 1/4" on the spacer longer stronger wheel studs are needed or go with an adapter.
Old Dec 13, 2005 | 10:13 AM
azteca's Avatar
Sorry, they are 65mm. The boxes the rims came with said 50mm. I just called the guy I bought them from and he said where 65mm in the rear. What can I do to make these rime look better and where can I buy it ? Thanks for the help.
Old Dec 13, 2005 | 02:51 PM
Xsta Z 28's Avatar
You need around a 15 mm spacer/adapter or 5/8" . . . try e-bay.
