suggestions on tire size
Old Dec 19, 2005 | 04:33 PM
02ZZ28's Avatar
Default suggestions on tire size
Im looking to replace my rear tires with a wider tire. I curently have stock chrome 02 z28 rims. Thr size is 245/50/16. how wide can I go? Is 265 too big? Id like to put a set of Kumho Ecsta MX on. Any and all info would be appreciated.
Old Dec 19, 2005 | 04:56 PM
Xsta Z 28's Avatar
255/50ZR16 is the widest you should go.
Old Dec 19, 2005 | 06:03 PM
02ZZ28's Avatar
Thank you
Old Dec 19, 2005 | 06:50 PM
Camaro396's Avatar
how wide is the rim 8?
Old Dec 19, 2005 | 07:49 PM
Xsta Z 28's Avatar
Yes they are.
Old Dec 19, 2005 | 08:46 PM
Camaro396's Avatar
what u cant fit a bigger tire than 255 under the car or what? Im running 295s on my 8 inch rims..
Old Dec 20, 2005 | 08:24 AM
Xsta Z 28's Avatar
Thumbs down
Becasue a 295 is not meant to be run on a 8" wheel . . .
What the hell is the point of running a 295 which is an 11 1/2" wide tire on a 8" wheel? The sidewalls would be so distorted the total width of the tread will not touch the ground . . .
255/50ZR16 is the largest RECOMMENDED tire for a 8" wheel . . . .
