Anyone use wheel spacers??
pulling the rear axle is a lot of work just to push the wheel out. if you use a spacer, get them that much longer than the stock stud so you can use the same lug nuts. if not you'll just have to use an open lug and that'll look weird.
You can really see the wheels sunk in there on this pic.
What you guys think? liveable?
I just found out my old centerline wheels(the ones that fit really good) were 17x9.5" w/7" backspace and a 44mm offset. SO that means my new Z06 wheels with the 54mm offset are sunk in about 7/16"(10mm) more then my old combo. Guess I gotta live with it but it makes the tires seem smaller then they are.
