? on Evo backspacing & offset after widening
my question is what backspacing and offset should i order the rear pair so that after they've been widened i wont need to use spacers?
other question i have is if i get them in hyperdark are they gonna have to strip them in order to do the welding then i have to have them repainted?
thanx
www.weldcraftwheels.com
If you're having inner fenderwell rubbing issues, it sounds like you probably have the 56mm offset. Did you do any BFH'ing?
Also, wasn't your post orginally about seeing of widened Evo's would fit? Where happened to that?
my question original was about the evo's and i appreciate the feedback.
if i understand you correctly; it would work fine to get the 19' evo's in 9inch width if i plan on widening them to 11inches because they only come in a 38mm offset.
and by the way i havent done the BFH mod yet and i just realized i have spacers from murrays between the wheel and hub to space the wheel out farther.
thanks again
