slp bump stop spacer
Old Jan 15, 2006 | 10:44 PM
atxfbody's Avatar
Default slp bump stop spacer
as i had in my other post the search mode is not working... I just put a set of 17x11 polished ZR1s on my camaro and was wondering if the slp bump stops spacers would prevent fender rub or will i have to roll the fenders?
Old Jan 16, 2006 | 12:44 AM
JGKadell's Avatar
No, they just make the rear end travel a tad bit shorter so the wider tires don't rub the upper inner parts of the wheel well.
Fender rub will depend on the backspacing on your wheels. I have 17x11 on mine with a 50mm BS and they fit fine.
