Will 15" rims fit on the rear wheels?
Old Jan 17, 2006 | 11:00 PM
blackbird345's Avatar
Default Will 15" rims fit on the rear wheels?
Does anyone know if 15" rims over the brakes?
Old Jan 17, 2006 | 11:26 PM
camaroextra's Avatar
the require 5.5 inch backspacing
Old Jan 18, 2006 | 01:06 AM
ninetres's Avatar
my buddy has 15"s all around, but I know he had to grind down at least the front 2 rotors.
So I guess I am really no help.
Pm Tondss, he would know.
Old Jan 18, 2006 | 01:44 AM
SJM Manufacturing Inc's Avatar
Here's many 15's we designed.
www.sjmmanufacturing.com/customer_cam.html
Old Jan 18, 2006 | 07:23 AM
Camaro396's Avatar
alot of people run 15 inch rims, me for one, and i know of alot of others, 15x8s need 5.5 backspacing and 15x10 need like 7.5 i believe.
Old Jan 18, 2006 | 09:07 AM
LS69TA's Avatar
Way back in the day in '98, I was at home and had a flat on the rear of my '98 T/A and had to throw on some 15x10 Eagle Alloys "Hammers" with some 245/50s that I had from my Ranger. They acutally fit without grinding. So I guess there are some 15's that will fit. I ran them for a week or 2.
Old Jan 18, 2006 | 10:09 AM
bigwillie's Avatar
I don't see alot of 5.5 inch backspace wheels around. Can you just run a spacer?
Old Jan 18, 2006 | 10:53 AM
FYI
ALL of the F-body pictures shown have at least a 10 inch wheel. 8 inch wheels are too small unless you only want to run smaller tires.
Old Jan 18, 2006 | 02:31 PM
Ok soooooo why do I need the back space? Is it because the rim/tire will rub against the shock or what? I will be using 8" wide slicks
Old Jan 18, 2006 | 03:34 PM
8 inch slicks are pretty small...you'll need a smaller 8 inch wheel. Unless a race-event dictates you have to run such a small tire, I woudln't consider it...it really is tiny... Our larger wheels and tires like you see on our site fit very easy with no modifcations grinding or spacers.
Old Jan 19, 2006 | 03:12 PM
Ok I've found a pair of rims they are 30X12.5 by 15. Any chance of these fitting? What part wouldn't fit? Can I safely remove the rear rotors and plug the brake line to make these wheels fit?
Old Jan 19, 2006 | 03:23 PM
No chance in fitting. You need to do some searching in the wheel section since it appears that you are not familar with what works on an F-body. This topic comes up all the time...information you need should be very simple to find.
If you do not want to search, as mentioned, I can set you up with exactly what will work and will fit your appliction without the need of grinding, adding spacers etc.
Our wheels are the lightest direct fit wheel on the market. You get what you pay for.
Steve
Old Jan 20, 2006 | 10:29 PM
bigdsz's Avatar
Weld Racing Engineering Dept. is currently evaluating the feasibility of modifying their current 15" barrel design to accomodate the rear Fbody calipers. If this change takes place moderately priced wheels at under $200 each will finally be available.
