wheel spacers, where to get them?
Old Jan 20, 2006 | 10:34 AM
z28_theantirice's Avatar
Default wheel spacers, where to get them?
I am looking for either a 3mm or 5mm wheel spacer what will fit my 95 Z, and I am having a hard time finding them, anyone that could point me in the right direction would be great thanks...
Old Jan 20, 2006 | 03:38 PM
Tdawg's Avatar
i got my spacers at the local tire place (big brand ithink)
Old Jan 20, 2006 | 04:57 PM
SJM Manufacturing Inc's Avatar
do you realize how small 3mm or 5 mm is? It's in-between 1/8 of an inch...think of it...about the thickness of two credit cards put together.
I don't think you'll ever notice a difference using them. If you are trying to clearance something...grind it to fit. THat is such a small amount!
Old Jan 20, 2006 | 06:35 PM
LETHL_SS's Avatar
Not sure if this is what you need but ThunderRacing has some HERE
Old Jan 20, 2006 | 08:35 PM
Well the reason I was wanting such a small spacer is because I have some 18x10.5 Z06's with a 58mm offset, and so if i were to get a 5mm spacer it would provide a little extra room and less banging on the inner fender well
Old Jan 20, 2006 | 09:05 PM
LETHL_SS's Avatar
I used the ones in the link I provided earlier to accomplish what you want and to also use closed ended lugnuts on my Moser.
Old Jan 22, 2006 | 06:05 PM
joshtownsend's Avatar
Why dont you use some washers? I might even have some grade 8 that will work. I used them on my truck and they worked fine.
Old Jan 22, 2006 | 09:18 PM
LS69TA's Avatar
I've got 1/8" IROC spacers on the rear of mine. You can probably find some pretty cheap. Look on Ebay or try www.thirdgen.org.
Old Jan 23, 2006 | 08:53 AM
785T/A's Avatar
I got some for a mock up from an off road store. 1/4 inch spacers
Old Jan 23, 2006 | 05:38 PM
jimmy 2 Times's Avatar
I believe with those rims, you will need a 1/2 - 3/4 in. spacers
Old Jan 25, 2006 | 08:51 PM
carado1984's Avatar
i have the same wheels as you, and same size tire.. customwheelsmarket.com.. 1/4 inch spacers is what you need... go to that site and give them a call.. they might be like ten for the pair i cant remember, but not much
