Dropping PSI?
Old Feb 14, 2006 | 06:02 PM
blind527's Avatar
Default Dropping PSI?
I hear that if you add air to a tire that is warm then you need to put about 4 PSI more than you would. If I rode my car to the track, and it's at 22 PSI, and wanted to bring it down to 16 PSI, would it be fine?
Old Feb 14, 2006 | 06:44 PM
Krab's Avatar
The way I read your post, you've got it the other way around. If you have 32psi in your tires and you drive around for a while until the tires warm up a bit, you'll be at about 35psi depending on how hot your tires get.
Old Feb 14, 2006 | 06:51 PM
blind527's Avatar
Maybe that's it. Do I just drop it down to what I would normally put it at?
Old Feb 14, 2006 | 07:09 PM
Krab's Avatar
I would just drive to the track, check the tire pressure in the staging lanes and lower it accordingly. They should have a compressor there anyways so you can bring the tire pressure up to a safer street level once you leave.
Old Feb 14, 2006 | 07:39 PM
blind527's Avatar
I'll just bring my handy foot pump.
Sounds good, thanks a lot.
