3.25 ARP wheel studs
Old Feb 15, 2006 | 06:53 PM
Doc's Avatar
Doc
Default 3.25 ARP wheel studs
Ok folks I am wanting to run some 15 x 10 weld 96 pro stars with a rear spacing of 7.5 I have selected 3.25 ARP wheel studs and have the wheel, caliper, parking brake, brake backer plate off and still don't see how I am going to get the 3.25 studs in the stock 10 bolt axel. Any suggestions? Thanks.
Old Feb 15, 2006 | 07:20 PM
co.6z28's Avatar
i think u gotta pull the axles
Old Feb 15, 2006 | 10:10 PM
IMJ's Avatar
IMJ
I read that you could take off the abs sensor and line it up with the stud and pound them out. and use the washer lugnut trick to pull them through... but i have never done it i need to because i broke one the other day on my car.... i hope someone else chimes in cause i am also wondering how to do this....
Old Apr 9, 2006 | 07:11 PM
Strahley's Avatar
You can get the stock studs out without removing any axles, but I don't see how it's possible to get anything bigger than a stock wheel stud in there without removing axles
Old Apr 18, 2006 | 01:12 PM
tunedportcj5's Avatar
You're gonna have to pull the axles. Hey, its a good excuse to change your diff fluid!
