Draglite lugnut specs?
Old Feb 17, 2006 | 10:39 AM
spectrez28's Avatar
Default Draglite lugnut specs?
Anyone happen to know the specs for weld draglite lugs for a 98 t/a with stock studs? Thanks!
Old Feb 17, 2006 | 11:08 AM
Nine Ball's Avatar
LS1Tech Co-Founder
12mm x 1.5 thread, long shank style. They make two different shank lengths, get the longer ones.
Old May 8, 2006 | 11:21 PM
'Trust''s Avatar
Where would someone go about getting these lugnuts?
Old May 10, 2006 | 11:33 AM
INMY01TA's Avatar
You can get the Mcgaurd lug nuts that'll fit at autopart stores. They're open ended to fit longer wheel studs but have a black removable cap at the end if you use the stock studs.
Old May 10, 2006 | 12:08 PM
GregWS6&z28's Avatar
id suggest staying away from the Weld brand lugnuts... after one use and getting wet mine and the washers started rusting
