Wheel Spacers Wanted Good/Bad?
Old Feb 21, 2006 | 11:27 PM
one2run's Avatar
Default Wheel Spacers Wanted Good/Bad?
i am having issues with my 11 inch wide ZR1's rubbing the inner fender well under hard cornering. i have already performed the BFH mod to it and can't stand to bang on my car anymore than what i have already done.
who here has used a spacer, and can give me an opinion on them? i would like to have about a .5 inch wide spacer for the rear, and 1.5 inch for the front to balance the stance out a little. where can i get them in this size, and is it even possible? thanks.
Old Feb 22, 2006 | 12:46 PM
one2run's Avatar
no one here uses a spacer?
Old Feb 22, 2006 | 12:59 PM
Deep Blue's Avatar
Do a search. I and many others have used and commented on them. Not to flame, but one gets tired of writing the same thing over and over.
Old Feb 22, 2006 | 03:35 PM
69TA's Avatar
Get brembo ones from Thunder Racing. Or look into H&R spacers
Good luck,
Kevin
Old Feb 23, 2006 | 11:14 AM
carado1984's Avatar
if its a spacer, dont do more than a 1/4 inch.. otherwise your looking at a bolt on adapter
Old Feb 23, 2006 | 01:24 PM
Deep Blue's Avatar
I owe you an apology. I just did a search for my own post and apparently it is no longer available.
I'm running two 1.25 inch thick hubcentric bolt on adapters for my 19X10 +79mm offset C6 rear rims. So far no problems. Use a torque wrench to make sure everything its tightened properly, but also that you don't overtorque the adapters. I bought mine on Ebay.
Old Feb 23, 2006 | 02:31 PM
777's Avatar
777
there are some sites that have adapters. Just do a google search on them. That's what you'll need. Don't run a spacer with that much room.
AND yes the search is "injured." It's been that way for a long time. That's what happens when you get 2000 people on a site designed for MUCH less than that. It works but only goes back so far.
