A.Z.A. Wheels
AZA RIMS
On a 9.5 wide wheel with that offset the wheel may stick out of the wheelwell 1/4 to 1/2 " in the front only so I would recomend going with 8.5s in the front. The rears should not be a problem, but you may want to roll the lips of the quarters to be safe.
I'm going with the Z8's in the staggered package 35mm offset on all 4 on my Formula.
Hope this helps in your decision
Oh BTW the 5x120 bolt pattern is not exactly the same as ours each stud will be .325mm off. Not really enough to worry about, you could always keep a torque wrench with you and check your lugs often.
good luck
