Hooking problems
Old Mar 16, 2006 | 12:52 PM
BirdmanLS1's Avatar
Default Hooking problems
Ok, I have a 98 formula and it has been lowered about 1.8 inches (eibach sportline springs) and new front shocks, but stock rear ones with 104k on the clock. I cant hook worth anything at all from a dig. Is this normal? or do i need to reposition my lca? I just want to be able to hook somewhat. I have tried dumping from 3k, 2.8k, 2.5k, 2.2k, 2k and i just spin every time. Is it cause i dont know what im doing or is there a reason why im not hooking? Thanks for input.
Old Mar 16, 2006 | 12:53 PM
BirdmanLS1's Avatar
oh btw, i have stock size nitto all weather tires... i think, lol not sure if they make nitto all weather tires, but i will check to make sure and post when i get home from work.
Old Mar 16, 2006 | 01:13 PM
BlackHawk T/A's Avatar
It's your tires.
Old Mar 16, 2006 | 01:36 PM
Xsta Z 28's Avatar
Bad tires. Are the LCA's relocated properly? The TA angle OK? . . . Springs probably don't have enough travel either . . . .
Old Mar 16, 2006 | 01:44 PM
ls1mongrel's Avatar
Get some good tire, nittos,bfg or MT drag radials and some relocation brackets and that should help alot !
Old Mar 17, 2006 | 01:10 PM
BirdmanLS1's Avatar
I dont have the LCA's relocated yet, i was asking if that would help? And you're thinkin I might need to get a torque arm relocation done? I am probably gonna get koni da shocks and maybe an lg coil over kit, so i will be able to adjust my ride height. Having more travel helps for traction? I am gonna get 11 inch drs later on, so that will hopefully fix my tire problem
Old Mar 20, 2006 | 08:03 AM
Xsta Z 28's Avatar
Take the changes in steps. First the relocation brackets. That should help, if you still have a problem then you need an adjustable torque arm.
