15x10
Old Mar 23, 2006 | 10:42 PM
roosteracer's Avatar
Default 15x10
will 15x10 tires go on my car? how much mods do i have to do? and what do i do?
Old Mar 23, 2006 | 11:16 PM
Cbrakllr's Avatar
hell ya, i had 15x10 draglites, i guess it depends if you want a drag wheel or a street rim.
Old Mar 24, 2006 | 10:33 AM
LS69TA's Avatar
If you have the $$, I'd recommend Bogarts. You won't have to grind the calipers and they look killer. If you're on a budget like alot of us, you can get Centerline Convo Pros or Warriors, but they don't have the ideal backspacing to keep the wheels from sticking outside the fenders. Or, you can get Weld Prostars or Draglites if you feel like grinding the rear calipers to make them fit. Ideally you want 7.5" backspacing for a 15x10, 5.5" for a 15x8. But the T/As have a little wider flare on the rear 1/4 panel, so I ran 6.5" bs on my Prostars and they looked fine. They were dead even with the top of the fender with 275/50/15 Nitto 555R's.
