Skinnys on front (LT1) HELP!!!!!!!
Old Mar 24, 2006 | 02:01 PM
bski224's Avatar
Default Skinnys on front (LT1) HELP!!!!!!!
I currently have 15x3.5's in front, they were fine until i changed my brake pads now there rubbing. I did have to grind down pad clips prior to new pads, now big time rubbing. I did grind down new clips and still rubbing. What is the correct backspacing for Weld's (front) and what do you guys think of spacers and what size do you recommend. If not will 15x4" rims work with different backspacing. Thanks!!!
Old Mar 24, 2006 | 05:16 PM
Speed Density's Avatar
hashtagBMW
5/16 spacers should do you just fine.
I think that the 15x3.5s are 1.75 BS.
Correct me if im wrong.
Old Mar 24, 2006 | 05:34 PM
LS69TA's Avatar
1.75 is the only offset available for the 3.5s. I'd just get the grinder out and take off a little more where it is rubbing. Or, try to find some 1/8" Iroc spacers and see if those will fix it. You can always use the 5/16 spacers, but I'd have longer studs put in if you were going to go that route.
