Spacers on the rear, do I need longer studs?
Old Mar 26, 2006 | 02:11 PM
talonis's Avatar
Default Spacers on the rear, do I need longer studs?
Hi,
I have 17x11" on the rear. I noticed that I was getting some slight rub with the tire on the inner wheel well and when the rear axle had no load (hanging) the wheel will lightly touch the bump stop. I have a spare set of Doug Rippie Motorsport 3/8" wheel spacers that I was going to put on to stop the rub. I know the fender can be bent with the BFH mod and the bump stop can be dremmeled, but it seems easier to just put on the spacers. My question is, is it safe to do so on the stock length wheel studs? It seems like there is still a decent amount of stud to grip with the lugs, but I don't want to have a wheel fly off during an autox event .
Thanks,
-S
Old Mar 26, 2006 | 04:22 PM
FSTLS1's Avatar
Do a search to make sure, but from what I understand, a 1/2" spacer or less is safe. A rule of thumb is putting on the lug nut 6 or more threads is safe.
Old Mar 26, 2006 | 05:42 PM
chupr0kabra's Avatar
1/4" spacers can be used safely with stock studs (hub-centric spacers, ideally). Anything more than than and you should probably get longer studes, just to be safe.
-Mike
Old Mar 26, 2006 | 07:02 PM
white_camaro's Avatar
i got 5/16 spacers on mine. doesnt catch a whole lot of thread but i make sure to torque them down to 105 tq/lbs and check them regularly, i havent had any problems and i doubt you will, just make sure to check them every now and then.
Old Mar 27, 2006 | 10:15 AM
JR HAWK 9's Avatar
I agree I wouldn't put anything bigger than a 1/4" spacer on w/o getting longer studs.
