drag radials and 10 bolt?
Old Apr 10, 2006 | 08:16 PM
liss87's Avatar
Default drag radials and 10 bolt?
will nitto drag radials blow out my stock 10 bolt i am a little worried. should i just stick with some good street tires?
Old Apr 10, 2006 | 08:43 PM
Ryan02SS's Avatar
Using DR's on a 10 bolt is similar to having sex w/o a condom. You might get by a few times but your gonna get something in the end. Some have gone into the 11's and some have broken their 10 bolts on street tires. On a borrowed set of 245 555R's I cut a 1.9 60 w current setup and the rear sounded like marbles in a can. I lifted immediately and coasted the rest of the track.
Old Apr 10, 2006 | 09:30 PM
JDP's Avatar
JDP
im going to buy some nittos, if it breaks, it breaks, just an excuse to save money for a 12 bolt or 9 inch
Old Apr 10, 2006 | 09:34 PM
LS144's Avatar
Old Apr 10, 2006 | 09:50 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The A4s aren't as hard on the 10 bolt and the 6-speed cars. I've cut a 1.73 with Nittos and the only suspension mods I have are Spohn LCAs and a TA rearend cover
Old Apr 10, 2006 | 09:54 PM
HowellSoccer88's Avatar
Mine help up for awhile on the street with Nittos til the other day when I wanted to be a badass The 10-bolt didnt take a liking to a 1-2 shift with a hundred shot too well. My gears were pretty much toothless circles Sucks because it was only the second time I sprayed.
