Balancing Slicks
should i use the hammer on weights. and at what pressure should i speed balance? i usally use 12-15psi at the track...
the other question is when the walls wrinkle (at a launch) will the side weights tear the side wall....... that my main concern i dont want to kill my self....
thanks for all your replies guys.....
im at 420 at the rear and i do spin the tire loose after a run (street slicks)
the tire does not stay still on the rim it moves about 1-3 in. (12-15 psi)
so what should i do....
but like said, your just gonna spin the weights off, or move the tire on the rim.
good luck
good luck
