Rear Wheel Hub
Old Apr 23, 2006 | 07:19 PM
BTTM's Avatar
Default Rear Wheel Hub
How do I remove this? Got a stripped wheel stud and I can't get the hub off.
Old Apr 24, 2006 | 12:34 AM
BackinBlack02SS's Avatar
You need to pull the cover off and remove the c clips. The axles will then slide out and you can install the new studs. You can cut a few corners and do it without removing the axles, but it's not recommended.
Old Apr 24, 2006 | 02:36 PM
BTTM's Avatar
Thanks for the info.
Old Apr 24, 2006 | 02:43 PM
2000Z28M6's Avatar
Its really not that hard, just makes you wish you had a lift in your garage.
Drain the rear, remove the cover, take a 7mm wrench and loosen the screw that holds the middle piece. Take out the middle piece. Push the axles in, remove the C clips. Axles should slide out.
Old Apr 24, 2006 | 05:13 PM
911ss's Avatar
i just changed out my studs and i didnt remove the rear hubs. just take off brake caliper, pull off disk. knock out old wheel stud. stick a pen magnet in from the front side of the hole the new stud is going through o help guide it. get a nut and tighen it down on the new stud to make it press and tighten down in he hole.
