Prostar help
Old May 12, 2006 | 12:35 PM
allblackSS's Avatar
Default Prostar help
I got a 2000 camaro i put some prostars on it and it broke alot of the wheel studs im running a 5/16 spacer with alot of caliper grinding i have 15.3.5 what size hardened wheel studs and length lug nuts will keep this from happening any help greatly appreciated.
thanks
Bubba
Old May 12, 2006 | 12:48 PM
ls2 bait's Avatar
if u run them all the time id go with the 3.25" arp studs and open end lug nuts.
Old May 12, 2006 | 12:52 PM
CrawlinWS6's Avatar
Import Patrol
That is exactly what I am running now. I run mine on the street more then at the track. Have not had any problems. And I am running the same size spacer as well.
Old May 12, 2006 | 06:24 PM
allblackSS's Avatar
thanks guys i about had a mess a few days oga when them suckers came off i appreciate the help
Old May 12, 2006 | 06:29 PM
CrawlinWS6's Avatar
Import Patrol
Good luck. Those arp are a bitch to get in. I had to have the fronts pressed in the hubs at a machine shop!
