Problems with my M/T's
Old May 13, 2006 | 07:00 PM
RedDragon009's Avatar
Default Problems with my M/T's
I just finished putting my M/T 325/50/15 drag radials and skinnies on and my e-brake light and my abs inop light will not go off. Has anyone else had this problem and what can I do to fix it?
Old May 13, 2006 | 09:25 PM
Ping King's Avatar
abs inop will go on because of the tire sizing difference.
the brake light may be unrelated..the switch is under the console for that one.
Old May 14, 2006 | 03:47 AM
bigradical's Avatar
Mine come on also. I ran my Predator and it was showing an unknown error code. I haven't had any problems so far though. By the way, how did you fit 315 M/T's on the back? I was going to run those but I was afraid they would be too big.
Old May 14, 2006 | 06:35 AM
Where under the dash is the e-brake light switch and what do I need to do? With the 325's a got a set of adj lca's and an adj lower panhardrod to help out. I had to remove the bumpstops and take a rubber mallet to the inner fenders.
Old May 14, 2006 | 12:23 PM
SLowETz's Avatar
As said above.... ABS and brake light will be a result of the different tire diameters. I run 28-12.50-15's Streets/ 26" Sportsman fronts.... lights are on... even pulled the TCS fuse. No biggie.... gives the dash some color
Old May 26, 2006 | 06:32 PM
phoenix's Avatar
the brake light comes on with the abs light
Old May 26, 2006 | 07:27 PM
NastyNate's Avatar
It does that even with a 26 inch tire? I would think the width wouldn't matter. Maybe it's the front skinnies that are a different height?
