C6 Wheels on a 2001 Camaro SS
Old May 31, 2006 | 08:16 PM
joe_2001SS's Avatar
Default Will Corvette C6 Wheels fit on a 2001 Camaro SS
I bought a set of 2006 corvette C6 wheels today for my 2001 SS. The fronts are 18x8.5 w/ 56 offset and the rears are 19x10 w/78 offset with Goodyear F1 245/40/18 & 285/35/19 TIRES. Does anyone know if these will fit right on there or do I need any special modifications? Not sure if the wheels will stick out too far or not far enough. It will take a few days for me to receive them and wanted to know what to expect.
Thanks
Old May 31, 2006 | 09:20 PM
Mike02Z's Avatar
Thanks
You should be OK in the front but you will certainly have issues in the rear. A +78mm offset is going to push the wheel too far into the wheel well and it will rub badly.You might need to get a spacer to make them fit in the back and use the BFH mod and or roll the fender lip. Oh, and since your new BFH= Big Fuc*ing Hammer. Basically you beat the crap out of the inner wheel well in the back where the tire rubs.
Old Jun 1, 2006 | 12:10 AM
joe_2001SS's Avatar
Thanks Mike.
Old Jun 1, 2006 | 12:10 PM
Bio Messiah's Avatar
78 offset doesnt sound right?
you might need to remove your bump stops completely.
I had 58mm offset on 18x9.5 and mine rubbed a little.
Old Jun 1, 2006 | 01:11 PM
Mike02Z's Avatar
Not perfect but very close. My buddy just bought a c6 and we replaced the wheels. they are +79mm offset's in the rear. I don't know if he can even get those mounted in the fbody wheel well they offset is so high.
Spacer should make them fit but I think he will need some major BFH work, cut the bumpstop and maybe even roll the lip. A lot of work for a set of wheels never meant to go on an fbody.
