Should I use Fix A Flat?
Old Jun 18, 2006 | 04:24 PM
pHEnomIC's Avatar
Default Should I use Fix A Flat?
Two tires on my Z have a slow leak that takes about a week for them to deflate. Not a big deal to me as I just fill em up every few days. Eventually I may end up giving this car to my sister and she won't be willing to do this.
There definentally aren't any punctures, Ive tried to find them before, I believe it is just poor tire to rim seal. The valve stems are also ok.
Can i just fill these two tires up with fix a flat? I realize I can go to the tire shop to get it fixed but I dont feel like spending that much at the moment because the car will need new tires soon anyways.
Old Jun 18, 2006 | 05:18 PM
93formto98T/A's Avatar
If it's in the tread area then it should seal it up but I've heard at high speeds it will cause problems cause your wheel/tire is no longer correctly balanced.
Old Jun 18, 2006 | 05:30 PM
SLP4CamaroSS's Avatar
dnot use fix a flat mess up your rims in the inside used to work at a tire place alot of the rims on the inside get eaten up and the tires arent balanced like 93formto98ta said
