Right backspacing?
Old Jul 2, 2006 | 05:08 PM
goodrich969's Avatar
Default Right backspacing?
2- 15x10 Convo-Pro, 5x4.75 bolt circle, 5" backspacing w/ 325x50
what will i have to do with that backspacing? anything to the rotors? because that tire is super wide.
Old Jul 2, 2006 | 07:28 PM
bump.
Old Jul 2, 2006 | 08:34 PM
LS69TA's Avatar
The Convo Pros don't require anything to fit over the calipers, but with the 5" backspacing, you'll end up with the rim an inch and a half outside the fender. With 325s, you will probably have issues with them rubbing the tops of the fenders.
Old Jul 3, 2006 | 12:23 PM
well how much fender work will i have to do.
Old Jul 3, 2006 | 02:33 PM
LS69TA's Avatar
Here is a link to some pics I found of 325s on a 10" rim with 6.5" backspacing. Yours will stick out another 1.5" further.
https://ls1tech.com/forums/showthrea...light=325+pics
Old Jul 3, 2006 | 02:35 PM
LS69TA's Avatar
You may have to trim the fenders, by how much depends on each car.
