245/50 ft 255/50 rr
Old Jul 3, 2006 | 05:01 PM
camcamaro1991's Avatar
Default 245/50 ft 255/50 rr
has anyone ran with this combo on factory 16"s??
pro's/con's??
Old Jul 3, 2006 | 06:36 PM
1999Z28's Avatar
it works fine
i upgraded to some 275/50/16s in the rear though
Old Jul 3, 2006 | 06:55 PM
98camaroLS1M6's Avatar
I run this now and have no problems. But you cannot rotate the tires and your speedometer will read about 1mph less at 60. Also, because the tire is .5inch taller (not much) but will make your gear ratio taller, but this really minor. Maybe instead of a 3.42, you will have a 3.40. Drag radials are 255s (mT and BFG) so I would def. go for it.
