tire question?
Old Jul 10, 2006 | 03:15 PM
dsster's Avatar
Default tire question?
sup guys, which one you guys prefer for rear tire size? 315/35/18 or 315/30/18..
i know alot of u guys using this tire here. i need tire for my new rims and im not sure if 35z or 30z is better for my 18inch rims thanx a lot....
Old Jul 10, 2006 | 03:34 PM
RpSS4844's Avatar
35's will be kind-of a tall sidewall. If your car is lowered or you plan on lowering i would use a 30. Either one will look ok, just depends on your preference on sidewall height. hope this helps. also do a search on the tire size and look at some pictures, and keep in mind its not a perfect world and different tires (brands) can look different.
Old Jul 10, 2006 | 04:39 PM
dsster's Avatar
RpSS4844 thx for the reply...
yes my car is lowered hav a eibach sportline on it and im thinking to put 35 cuz i want the rear end to look high, im runing 275/40/17 on the front.
i did my research but for some reason i didn't read anything about 315 on a 18inch or i probably just miss it.
Old Jul 10, 2006 | 04:50 PM
98redM6's Avatar
315/30/18 would be closer to the stock diameter size at 25.5" where a 315/35/18 would be a 26.4" diameter. I think I'd go with a 315/30/18 since it will be closer to the stock diameter and there are more tires available in that size, but a 315/35/18 will be okay though.
Old Jul 10, 2006 | 04:55 PM
RpSS4844's Avatar
^^ well put, i forgot to mention about the diameters of each. Also something to think about concerning different diameters, is ABS. I have seen one or two people on here that had differnet diamtertires front and rear and it caused their ABS light to come on. I have only seen a handful of these cases out of the many that are running different tires front/rear. Even though small percentage, its something to consider. hope this help.
