4.5 Backspacing not good?
Old Jul 16, 2006 | 12:22 PM
goodrich969's Avatar
Default 4.5 Backspacing not good?
15x8 draglites 4.5 bs
is that backspacing to small or too big, im not really sure about backspacing. I did research and i cant find anything about that backspacing.
Old Jul 16, 2006 | 12:50 PM
SJM Manufacturing Inc's Avatar
My response must not have been clear enough for you in your last post. Please re-read it.
The backspace and the wheel is too small. You'll have to do significant modifications including grinding the calipers, adding spacers AND changing to longer 3" studs min. Hopefully this is clear enough for you. F-bodies need 10" wheels, not 8" which is too small for the typical tire setup.
