tire pressure ???
Old Jul 28, 2006 | 02:00 PM
billyb's Avatar
Default tire pressure ???
hi all whats the best tire pressure for 17" wheels sumiotto hrtz tires i had 51 psi max pressure but now i have 45 psi i still don't know ???? what do you think,prev owner ran 51 psi ?????????? thanks i have a 02 firehawk.
Old Jul 28, 2006 | 02:08 PM
RedWS6 00's Avatar
Blimey that sounds high. Running 30psi on mine, thought it said something like that on the sticker inside the drivers door.
Old Jul 28, 2006 | 03:41 PM
Viper's Avatar
Good lord, 51 !!!????!!!!!
Seriously, 30-32 is fine.
Old Jul 28, 2006 | 03:59 PM
Driving FaSSt's Avatar
i go 5 - 6 psi under what the max psi on the tires say
It says 51 so 46 or so will be fine
Old Jul 28, 2006 | 04:05 PM
BitViper's Avatar
Thats pretty much my thinking....trying to allow for expansion when the tire gets hot...
My D3's mak pressure is 50 and I run at 40...you'll get better tread life and tire performance..unless you drag racing..then Im betting you need all the sidewall flex you can get..
