Will This work?
Old Aug 15, 2006 | 05:32 PM
BirdmanLS1's Avatar
Default Will This work?
Im tryin to get a set of CCW 19x13 in the rear and 18x11 in the front. Will this work??? With Koni SA shocks w/ground control kit. Will be installing a 12 bolt rear end, and will have the Eradispeed+Kit. Thanks for the input.
Old Aug 16, 2006 | 02:27 PM
Xsta Z 28's Avatar
I doubt you'd ever get 13" wide wheels to ever fit with out MAJOR mods . . .
Old Aug 16, 2006 | 03:00 PM
LS69TA's Avatar
Probably going to have to do some major cutting of the inner fenderwells, and severely notching the LCAs or moving them inward.
Old Aug 16, 2006 | 10:41 PM
BirdmanLS1's Avatar
Ok, I will probably go with 11 inch tires? more reasonable? Or will that require modification. What is stock? 8 inches?
Old Aug 16, 2006 | 10:43 PM
SSilverSSurfer's Avatar
11's will be fine, mini tub for the 13's
