View Poll Results: What do you use?
Compressed Air(78% nitrogen/21% Oxygen/1% Other)
77.42%
100% Nitrogen
19.35%
Other
3.23%
Voters: 31. You may not vote on this poll
Nitrogen or Oxygen filled???
Old Aug 26, 2006 | 08:20 PM
Packy's Avatar
Originally Posted by ArcticZ28
I fill mine with helium. It's lighter than air, easier to
Helium has been known to leak past some types of valves because its molecules are very small!
Old Aug 27, 2006 | 10:16 AM
LTSpeed's Avatar
Originally Posted by jimmyblue
The only thing that matters is the humidity in the
compressed air, vs none in dry nitrogen. The stuff you get out of a coin-op air pump at the Stiffy Mart parking lot in Florida, is like mist. Bone dry air
is plenty good enough and will swing pressure only as far as gas law says; water though, swings at vapor pressure curve instead.
Ding ding ding!! All these posts and only one right answer. For the rest of you, we have some lovely parting gifts. Johnny, tell them what they've won...
Old Aug 27, 2006 | 10:37 AM
DadsYellowGoat's Avatar
Just a slight error here. ALL gases are effected by temperture, Charles Gas Law. Some chemistry 101. The effect in compressed air is from the moisture as stated earlier in the thread dry air will show less change of pressure then compressed air without a dryer. How many times have you seen someone discharging an airline and a stream of water shoots out. But the reality of all of this, is it really needed. I check my tire pressure every week while I am washing the car.
Old Aug 27, 2006 | 05:00 PM
70Stang's Avatar
Well we did an actual test with both -
Regular pump air -
30PSI in the tires, COLD.
Did a 10second burnout.
36PSI in the tires HOT.
Nitrogen-
30PSI in the tires HOT.
I work at a speedshop that shares a building with a tire shop....I was SUPER skeptical about the nitrougen when they got it....Needless to say, I will run it in all my cars from now on.
It really does work.
Old Aug 28, 2006 | 07:30 AM
LTSpeed's Avatar
Originally Posted by 70Stang
Well we did an actual test with both - I work at a speedshop that shares a building with a tire shop....I was SUPER skeptical about the nitrougen when they got it....
Yeah, it does work. But not everyone understands why. If you got compressed dry air out of a cylinder, you'd get the same results--or really really close. At 30psi, you'd go up to about 31psi in your test. On a race car that's the difference between the car having a push or not--and that's tire-by-tire. On a street car, it's not even detectable.
99% of the shops out there pushing nitrogen don't even know why they're doing it--except that people will pay more for it. That said, since most shops don't worry about the quality of their shop air, nitrogen isn't a bad choice to guarantee low moisture content. It would be cheaper for shops to put dryers on their compressors....but then they couldn't sell it as something special, could they?
Old Aug 28, 2006 | 12:00 PM
tinytimsolderbrother's Avatar
Default i wouldnt bother
I wonder if you filled them with propane if you would get better traction!?!?
Old Nov 3, 2006 | 12:24 PM
Brian2006's Avatar
I fill my MT ET streets with nitrogen because the temperature doesn't change as easily. That way you have a steady amount of pressure thruought
Old Nov 4, 2006 | 09:14 PM
wabmorgan's Avatar
Hank Hill, Assistant Manager at Strickland Propane says, "YES"
Old Nov 4, 2006 | 09:20 PM
wabmorgan's Avatar
om-mm..... I don't think he was serious about that.
Old Nov 6, 2006 | 01:51 AM
2002_Z28_Six_Speed's Avatar
Does the A-Team do that for their shows? They shoot the tire and the tire explodes, flipping over the car in flames?
Old Nov 6, 2006 | 04:04 PM
speed_demon24's Avatar
For a street car no one would know the difference. And you don't need different valve stems for nitrogen. Like it has been said, nitrougen has no moisture in it so the pressure wont fluctuate as much. Race teams do this to keep the pressures more constang, but they still go up in pressure alot more than you think. For a street car though its not worth anything.
