Prostars Question
Old Sep 14, 2006 | 04:53 PM
01_ram-air's Avatar
Default Prostars Question
I just want to make sure that I have the right size before I buy
15 x 3.5, 5 x 4.75, 1.75" backspacing.
15 x 8, 5 x 4.75, 5.5 " backspacing.
Am I going to have to grind the brakes?
I plan on running 275 50 15 M/t ET street Radials.
What fronts do you guys recommend?
What else am I going to have to buy?
Thanks in advance.
Old Sep 14, 2006 | 05:06 PM
DarkFormula's Avatar
You'll need 1/4" spacers for the fronts. The rears will fit, but a decent amount of grinding is involved around the outer circumference of the calipers.
I run this identical setup, BTW. I use just generic metric tires for the front, like $23/each from Pep Boys. I also run 275/50/15 BFGs for the rear, and cut low 1.6 60' with 12psi. The fronts see about 48psi.
Old Sep 14, 2006 | 05:08 PM
Oh, I just read your sig. These aren't going to be your daily driver wheels, are they? I used mine for street duty on the weekends, and it sucks with the skinnies. You lose all handling and all braking capabilities, with the exception of light duty.
Old Sep 14, 2006 | 07:38 PM
lethal93ta's Avatar
I have 15x4s up front 1 5/8 back space with M/T sportsman tires, on the back I have 15x10s 5 inch back space (I have my rear narrowed 2 inches a side) with 26 11.5 15 M/T ET streets.I have an LT1 so my brakes are a little smaller, I didnt have to grind mine at all.
Old Sep 15, 2006 | 11:14 AM
01_ram-air's Avatar
Thanks for the pics Lethal, car looks good.
I'm running the stock rear still and I want to still run a 26" tire.
Am I going to need different lug bolts?
Old Sep 15, 2006 | 03:33 PM
You'll need shouldered lug nuts with washers.
Old Sep 15, 2006 | 07:02 PM
lethal93ta's Avatar
mine take the Acorn/Conical not the shouldered type.
