Different tire sizes affecting ABS???
This is very serious, I had no idea this would happen when I purchased my Mt/Et streets..
This is all starting to make total sense now. Thanks for all the input. Boy the rollout is so slight in difference yet the damn ABS is VERY smart when it comes to this and is sensing it! WOW!!!
Let's assume the rear DRs "bite" better than the F1's, so under hard braking the fronts should start sliding before the rears as if the fronts were on a slippery surface and the rears were not. The ABS releases pressure on the slower turning wheel because it is programmed to think that tire is sliding, so it releases brake pressure on the fronts but not the rears.
Now in a hard stop the fronts are doing 70-80% of the stopping, mainly because we are starting with a front heavy (54-55%) car which transfers weight forward under braking. The worst case is fronts locking (sliding) and the rears gripping. You lose MOST of your braking ability. This sounds like your condition on both cars.
If you were to disable the ABS perhaps by pulling a fuse, and did some controlled braking trials you could determine which end is locking up. If it's the front, you need to get the fronts biting like the rears or vice versa.
Solutions? You could put DRs on the front also. 5-6000 miles is probably about all you'll get on DRs. You could put F1s on the rear and save the DRs for the strip. I strongly suggest you take action on this problem.
My $.02
Only if the diameter of the wheels and tires is different not the width.
Are you familiar with threshold braking? If not, you should become familiar with it, and soon.
My $.02
