M T RAdials and Drag Lites
Old Oct 4, 2006 | 12:30 PM
sunsetorang01TA's Avatar
Default M T RAdials and Drag Lites
alrite so i want to get some 275 40R 17 M T Radials and Drag Lites for the back. Anybody have this set up currently. did you run into problems getting um to fit or grinding the calipers down. Also what else is needed for this set up. I heard that you have to get different lug nuts but im not sure which ones i need?
Old Oct 4, 2006 | 02:58 PM
2002_Z28_Six_Speed's Avatar
I think 17'' MT would be hard to come by compared to 15'' or 16''.
Maybe you are refering to lugs with a stepped edge instead of an acorn shape. That way it doesn't dig into the alum wheel as the hole is drilled smaller.
