wheels
Old Oct 29, 2006 | 04:59 PM
mike02ss's Avatar
Default wheels
Will a stock suspension 2002 ss fit a 18 x 9 in the front with stock offset of 56 using a 265/40/18 fit without rubbing? Also will a 18 x 9.5 using the same size 265/40/18 with 50mm offset fit okay in the rear? Trying to keep the same size diameter front to rear. Thanks
Old Oct 30, 2006 | 10:57 AM
Xsta Z 28's Avatar
It would be fine, but I'd getter a 275/35ZR18 tire . . . . The 265, will look narrower than the wheel, especially on the 9.5" wheel . . .
Old Oct 30, 2006 | 11:46 AM
Xx01CamaroZ28xX's Avatar
Yea like Xsta said, you should have no problem getting it to fit on your car. But a 275 would look a whole lot better, plus a little more tread for your ride to grip with......
