PSI in 275/40/17
Old Nov 13, 2006 | 11:01 PM
Mystic97ta's Avatar
Default PSI in 275/40/17
I just got 17" WS6 wheels for my TA, what pressure are the tires supposed to be at?
Thanks!
Old Nov 13, 2006 | 11:33 PM
Donohue96M6Z28's Avatar
look on the tire?
Old Nov 14, 2006 | 12:12 AM
Mystic97ta's Avatar
The tires have max psi on them I want to know what they are supposed to be run at for our cars. Thanks.
Old Nov 14, 2006 | 05:39 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
GM says 30psi for these cars (it's on the door sticker). That's for both the 245/50/16 and the 275/40/17 tires.
Old Nov 14, 2006 | 06:42 AM
ws6on19s's Avatar
38psi.. any less and your car will feel like a sponge any more and youll rattle your teeth out and the tires will wear uneven
EroC
Old Nov 14, 2006 | 08:43 AM
sscamaroburn02's Avatar
Ive always just put 34psi in all my tires. They have always worn perfectly.
Old Nov 14, 2006 | 08:45 AM
'Trust''s Avatar
EroC
What? No. Thats way too much for daily use. 30-32 PSI is whats recommended. The car won't feel like a sponge unless your running on something with no sidewall.
Old Nov 14, 2006 | 09:58 AM
Dal1as's Avatar
Depends on the tire but anywhere from 31 to 34 psi I've found is perfect. I usually run 33 in the front and 31 in the rear.
Old Nov 14, 2006 | 07:45 PM
RPM WS6's Avatar
EroC
Too much, IMO.
Old Nov 14, 2006 | 07:53 PM
Arachnotron's Avatar
I run 30psi.
Old Nov 14, 2006 | 08:01 PM
SuperSport4life's Avatar
