Installed 315's this weekend
http://img368.imageshack.us/my.php?i...5pt2001ac7.jpg
http://img368.imageshack.us/my.php?i...5pt2008if1.jpg
http://img368.imageshack.us/my.php?i...5pt2009ah8.jpg
http://img368.imageshack.us/my.php?i...5pt2005if9.jpg
http://img85.imageshack.us/my.php?im...5pt2004id3.jpg
Actually...someone just send me a PM with pics posted in the message directly, and he had image shack...so maybe it's not them?
I guess you're doing it wrong then? Just use {img} and {/img} but with [] and stick the url of the pic between them....works for me.
All you need to do is put this minus the quotation marks: "[img] YOUR LINK [/img]"
Edit: I usually use the last link selection they offer once you upload the picture - Direct Link
I think its one of the front (275/40/17) sized are the ones 'really' hard to get ahold of right now.
When I get mine, I want a complete set. I hate nothing more than having different looking tires on my car. For some reason I did manage to wear out the fronts just as badly as the rears...lol
With stock LCA's, I had to bang in the outer lip of the LCA on both sides, as well as use the BFH on the inner rear fender. This was using AFS ZR1 50mm 17x11's and Kumho 315/35/17 V710's . Still had some minor inside rubbing, so I threw on a 7/32" spacer. I have to remove that spacer when I use my street wheels else they rub on the fender under compression. 710's have a pretty rounded shoulder so no problem with the fender.
I recently switched to Dunlop 290/645R17 slicks, which are just as wide as the 315's but the shoulders are basically square, and no problems at all also using the spacer.
