Pontiac wheel question?
Old Nov 26, 2006 | 08:46 AM
Jeff 97 Formula's Avatar
Default Pontiac wheel question?
I took this from http://www.tacreationsusa.com/firebi...els.htm#Chrome. How can this be possible? I thought chrome wheels were introduced in 1995. If this is true, how can I be sure the wheels I get from lakeshorewheelandtire.com will fit my 97 Formula? Their site says 1993-2002.
Chrome wheel interference problems on 93-96 F-bodies : Chrome wheels will not fit on rear of 93-95 Firebirds due to a lack of clearance between the wheel hub and the rear axle shaft. Factory 93-96 axle shafts have a 70.75 mm diameter hub face, while the 97-02 Chrome wheels have a 70.5 mm diameter hub opening. Minor grinding/machining is mandatory for installing those wheels on 93-96 models
Old Nov 26, 2006 | 03:00 PM
wabmorgan's Avatar
The fix for this is easy. Their is only a .25mm differance in diameter.
Take a dremel and sand out the inside of the wheel hub hole.(Large hole in the middle) You don't need to take out much, only about the thickness of a human hair. JUst sand out all the way around. The hub doen't center the wheel anyway, so it won't matter. The lugs center the wheels.
Old Nov 26, 2006 | 05:08 PM
My 97 Formula actually came with chrome wheels from the factory, but the wheels are starting to flake. I'm thinking about buying new wheels of the same kind. I guess my real question is this: Are all Firebird 16x8 chrome wheels the same?
